Stuttering Equivalence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
Two omega-sequences are stuttering equivalent if they differ only by finite repetitions of elements. Stuttering equivalence is a fundamental concept in the theory of concurrent and distributed systems. Notably, Lamport argues that refinement notions for such systems should be insensitive to finite stuttering. Peled and Wilke show that all LTL (linear-time temporal logic) properties that are insensitive to stuttering equivalence can be expressed without the next-time operator. Stuttering equivalence is also important for certain verification techniques such as partial-order reduction for model checking. We formalize stuttering equivalence in Isabelle/HOL. Our development relies on the notion of a stuttering sampling function that identifies blocks of identical sequence elements.
Fichier non déposé
hal-00760690 , version 1 (04-12-2012)
  • HAL Id : hal-00760690 , version 1
Stephan Merz. Stuttering Equivalence. [Research Report] 2012. ⟨hal-00760690⟩
164 Consultations
0 Téléchargements
