Fundamental principles of data assimilation underlying the Verdandi library: applications to biophysical model personalization within euHeart - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Medical and Biological Engineering and Computing Année : 2013
We present the fundamental principles of data assimilation underlying the Verdandi library, and how they are articulated with the modular architecture of the library. This translates -- in particular -- into the definition of standardized interfaces through which the data assimilation library interoperates with the model simulation software and the so-called observation manager. We also survey various examples of data assimilation applied to the personalization of biophysical models, in particular for cardiac modeling applications within the euHeart European project. This illustrates the power of data assimilation concepts in such novel applications, with tremendous potential in clinical diagnosis assistance.
specIssue-euHeart.pdf (319.93 Ko) Télécharger le fichier
hal-00760887 , version 1 (04-12-2012)
Dominique Chapelle, Marc Fragu, Vivien Mallet, Philippe Moireau. Fundamental principles of data assimilation underlying the Verdandi library: applications to biophysical model personalization within euHeart. Medical and Biological Engineering and Computing, 2013, 51, pp.1221-1233. ⟨10.1007/s11517-012-0969-6⟩. ⟨hal-00760887⟩
806 Consultations
593 Téléchargements
