Authenticating Operation-based History in Collaborative Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hien Thi Thu Truong
  • Fonction : Auteur
  • PersonId : 912859
Claudia-Lavinia Ignat
Within last years multi-synchronous collaborative editing systems became widely used. Multi-synchronous collaboration maintains multiple, simultaneous streams of activity which continually diverge and synchronized. These streams of activity are represented by means of logs of operations, i.e. user modifications. A malicious user might tamper his log of operations. At the moment of synchronization with other streams, the tampered log might generate wrong results. In this paper, we propose a solution relying on hash-chain based authenticators for authenticating logs that ensure the authenticity, the integrity of logs, and the user accountability. We present algorithms to construct authenticators and verify logs. We prove their correctness and provide theoretical and practical evaluations.
group155-truong.pdf (792.77 Ko) Télécharger le fichier
hal-00761045 , version 1 (04-12-2012)
Hien Thi Thu Truong, Claudia-Lavinia Ignat, Pascal Molli. Authenticating Operation-based History in Collaborative Systems. ACM 2012 International Conference on Support Group Work, Oct 2012, Sanibel Island, FL, United States. pp.131-140, ⟨10.1145/2389176.2389197⟩. ⟨hal-00761045⟩
270 Consultations
474 Téléchargements
