Intrinsic Images by Clustering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2012
Decomposing an input image into its intrinsic shading and reflectance components is a long-standing ill-posed problem. We present a novel algorithm that requires no user strokes and works on a single image. Based on simple assumptions about its reflectance and luminance, we first find clusters of similar reflectance in the image, and build a linear system describing the connections and relations between them. Our assumptions are less restrictive than widely-adopted Retinex-based approaches, and can be further relaxed in conflicting situations. The resulting system is robust even in the presence of areas where our assumptions do not hold. We show a wide variety of results, including natural images, objects from the MIT dataset and texture images, along with several applications, proving the versatility of our method.
EGSR_IntrinsicImages.pdf (36.36 Mo) Télécharger le fichier
Teaser.pdf (401.03 Ko) Télécharger le fichier
Format : Autre
hal-00761400 , version 1 (06-12-2012)
Elena Garces, Adolfo Munoz, Jorge Lopez-Moreno, Diego Gutiérrez. Intrinsic Images by Clustering. Computer Graphics Forum, 2012, Rendering 2012, 31 (4), pp.1415-1425. ⟨10.1111/j.1467-8659.2012.03137.x⟩. ⟨hal-00761400⟩
Collections
INRIA INRIA2
187 Consultations
144 Téléchargements
