Asymptotic preserving schemes for the Klein-Gordon equation in the non-relativistic limit regime - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerische Mathematik Année : 2014
We consider the Klein-Gordon equation in the non-relativistic limit regime, i.e. the speed of light c tending to infinity. We construct an asymptotic expansion for the solution with respect to the small parameter depending on the inverse of the square of the speed of light. As the first terms of this asymptotic can easily be simulated our approach allows us to construct numerical algorithms that are robust with respect to the large parameter c producing high oscillations in the exact solution.
kgr3.pdf (566.96 Ko) Télécharger le fichier
hal-00762161 , version 1 (06-12-2012)
Erwan Faou, Katharina Schratz. Asymptotic preserving schemes for the Klein-Gordon equation in the non-relativistic limit regime. Numerische Mathematik, 2014, 126 (3), pp.441-469. ⟨10.1007/s00211-013-0567-z⟩. ⟨hal-00762161⟩
212 Consultations
241 Téléchargements
