Accessibility for Plurals in Continuation Semantics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2013
Sai Qian
  • Fonction : Auteur
  • PersonId : 764456
  • IdRef : 182066258
Maxime Amblard
This paper accounts for the semantics of plurality, in particular, the accessibility relation for plural anaphoras. Two types of dis- course antecedents formations, inherited from the classical treatment [14], namely summation and abstraction, are studied in detail. Solutions for each phenomenon are provided respectively by introducing two new functions Sum and Abs, for obtaining the semantic interpretations. The technical background in this paper is based on a recently proposed dynamic semantic framework [9], which pertains a style of the traditional Montague Grammar and the principle of compositionality, without adding any new concept to classical logic.
Accessibility_for_Plurals_in_Continuation_Semantics.pdf (387.66 Ko) Télécharger le fichier
presentation_Accessibility_for_Plurals_in_Continuation_Semantics.pdf (1.7 Mo) Télécharger le fichier
Format : Autre
hal-00762203 , version 1 (06-12-2012)
Sai Qian, Maxime Amblard. Accessibility for Plurals in Continuation Semantics. Motomura Yoichi; Butler Alastair; Bekki Daisuke. New Frontiers in Artificial Intelligence - JSAI-isAI 2012 Workshops, LENLS, JURISIN, MiMI, Miyazaki, Japan, November 30 and December 1, 2012, Revised Selected Papers., 7856, Springer International Publishing, pp.53-68, 2013, Lecture Notes in Computer Science, 978-3-642-39931-2. ⟨10.1007/978-3-642-39931-2_5⟩. ⟨hal-00762203⟩
271 Consultations
591 Téléchargements
