Abstraction-based Malware Analysis Using Rewriting and Model Checking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a formal approach for the detection of high-level malware behaviors. Our technique uses a rewriting-based abstraction mechanism, producing abstracted forms of program traces, independent of the program implementation. It then allows us to handle similar be- haviors in a generic way and thus to be robust with respect to variants. These behaviors, defined as combinations of patterns given in a signa- ture, are detected by model-checking on the high-level representation of the program. We work on unbounded sets of traces, which makes our technique useful not only for dynamic analysis, considering one trace at a time, but also for static analysis, considering a set of traces inferred from a control flow graph. Abstracting traces with rewriting systems on first order terms with variables allows us in particular to model dataflow and to detect information leak.
esorics-definitif.pdf (239.78 Ko) Télécharger le fichier
hal-00762252 , version 1 (10-12-2012)
Philippe Beaucamps, Isabelle Gnaedig, Jean-Yves Marion. Abstraction-based Malware Analysis Using Rewriting and Model Checking. ESORICS - 17th European Symposium on Research in Computer Security - 2012, Sep 2012, Pisa, Italy. pp.806-823, ⟨10.1007/978-3-642-33167-1⟩. ⟨hal-00762252⟩
291 Consultations
623 Téléchargements
