Using Neuronal States for Transcribing Cortical Activity into Muscular Effort - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Octave Boussaton
  • Fonction : Auteur
  • PersonId : 758867
  • IdRef : 145018547
Laurent Bougrain
We study the relations between the ac- tivity of corticomotoneuronal (CM) cells and the forces exerted by fingers. The activity of CM cells, located in the primary motor cortex is recorded in the thumb and index fingers area of a monkey. The activity of the fingers is recorded as they press two levers. The main idea of this work is to establish and use a collection of neuronal states. At any time, the neuronal state is defined by the firing rates of the recorded neurons. We assume that any such neuronal state is related to a typical variation (or absence of variation) in the muscular effort. Our forecasting model uses a linear combination of the firing rates, some synchrony information between spike trains and averaged variations of the positions of the levers.
Boussaton-EMBC12REV.pdf (591.59 Ko) Télécharger le fichier
hal-00762310 , version 1 (06-12-2012)
  • HAL Id : hal-00762310 , version 1
Octave Boussaton, Laurent Bougrain. Using Neuronal States for Transcribing Cortical Activity into Muscular Effort. EMBC - 34th Annual International Conference of the IEEE Engineering in Medicine and Biology Society - 2012, Aug 2012, San Diego, United States. ⟨hal-00762310⟩
133 Consultations
197 Téléchargements
