Experimental study of the following dynamics of pedestrians - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We report some experimental study of the behavior of pedestrians when they follow each other. In the frame of the PEDIGREE project, trajectories of pedestrians walking along a one-dimensional path were tracked through a high-precision motion capture. Data analysis allowed to obtain the fundamental diagram at different scales. Two unexpected transitions in the way pedestrians follow each other have been evidenced. The interest of the experiment is to capture at the same time microscopic and macroscopic characteristics of the flow. Indeed, macroscopic structures such as stop-and-go waves can also be studied from the data. Eventually, a data-based following model has been proposed. Its calibration/validation can be performed both at the microscopic or macroscopic level. It is possible to extend the model to quasi-one-dimensional flows for the modeling of pedestrian flows in corridors.
Fichier non déposé
hal-00762937 , version 1 (09-12-2012)
Cécile Appert-Rolland, Asja Jelic, Pierre Degond, Jérôme Fehrenbach, Jiale Hua, et al.. Experimental study of the following dynamics of pedestrians. Pedestrian and Evacuation Dynamics 2012, Jun 2012, zurich, Switzerland. ⟨10.1007/978-3-319-02447-9_25⟩. ⟨hal-00762937⟩
393 Consultations
0 Téléchargements
