XtreemOS: a Sound Foundation for Cloud Infrastructure and Federations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2010
XtreemOS is a Linux-based operating system with native support for virtual organizations (VO's), for building large-scale resource federations. XtreemOS has been designed as a grid operating system, supporting the model of resource sharing among independent administrative domains. We argue, however, that the VO concept can be used to establish either resource sharing or resource isolation, or even both at the same time. We outline XtreemOS' fundamental properties and how its native VO support can be used to implement cloud infrastructure and cloud federations.
xtreemos-cloud.pdf (52.75 Ko) Télécharger le fichier
hal-00762954 , version 1 (09-12-2012)
Thilo Kielmann, Guillaume Pierre, Christine Morin. XtreemOS: a Sound Foundation for Cloud Infrastructure and Federations. Desprez, F. and Getov, V. and Priol, T. and Yahyapour, R. Grids, P2P and Services Computing, Springer, 2010, 978-1-4419-6793-0. ⟨10.1007/978-1-4419-6794-7_1⟩. ⟨hal-00762954⟩
354 Consultations
187 Téléchargements
