Flow-Level Stability of Multihop Wireless Networks Using Only MAC-Layer Information - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
It is by now well-known that wireless networks with file arrivals and departures are stable if one uses -fair congestion control and back-pressure based scheduling and routing. In this paper, we examine whether -fair congestion control is necessary for flow-level stability. We show that stability can be ensured even with very simple congestion control mechanisms, such as a fixed window size scheme which limits the maximum number of packets that are allowed into the ingress queue of a flow. A key ingredient of our result is the use of the difference between the logarithms of queue lengths as the link weights. This result is reminiscent of results in the context of CSMA algorithms, but for entirely different reasons.
p9-ghaderi.pdf (398.61 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-00763162 , version 1 (10-12-2012)
  • HAL Id : hal-00763162 , version 1
Javad Ghaderi, R. Srikant. Flow-Level Stability of Multihop Wireless Networks Using Only MAC-Layer Information. WiOpt'12: Modeling and Optimization in Mobile, Ad Hoc, and Wireless Networks, May 2012, Paderborn, Germany. pp.9-14. ⟨hal-00763162⟩
Collections
WIOPT2012
30 Consultations
68 Téléchargements
