Characterizing the Throughput Gain of Single Cell MIMO Wireless Systems with Full Duplex Radios - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Using additional antennas and signal processing techniques to build a full-duplex radio is becoming a popular topic in the networking research community. However, additional antennas are used for MIMO (multiple input multiple output) transmissions, traditionally, and it is well-known that increasing the number of antennas on either transmitter or receiver side increases the MIMO link capacity. Therefore, deployment of extra antennas on a transceiver has twofold applications, first increasing the capacity of half-duplex MIMO link, second providing full-duplex capability for the radio. In this work, we look at the performance comparison between using multiple-antennas for capacity enhancement in a half-duplex MIMO link with that of utilizing them to build a full-duplex radio. Our results indicate that under certain conditions, using additional antennas for building full-duplex radio can provide performance boost compared to utilizing them to form a high capacity MIMO link
p68-barghi.pdf (424.34 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-00763336 , version 1 (10-12-2012)
  • HAL Id : hal-00763336 , version 1
Sanaz Barghi, Mohammad A. Khojastepour, Karthikeyan Sundaresan, Sampath Rangarajan. Characterizing the Throughput Gain of Single Cell MIMO Wireless Systems with Full Duplex Radios. WiOpt'12: Modeling and Optimization in Mobile, Ad Hoc, and Wireless Networks, May 2012, Paderborn, Germany. pp.68-74. ⟨hal-00763336⟩
Collections
WIOPT2012
161 Consultations
279 Téléchargements
