Non-Cooperative Association Of Mobiles To Access Points Revisited - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider in this paper games related to the association problem of mobiles to an access point. It consists of deciding to which access point to connect. We consider the choice between two access points or more, where the access decisions may depend on the number of mobiles connected to each one of the access points. We obtain new results using elementary tools in congestion and crowding games.
p185-hasan.pdf (442.11 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-00763628 , version 1 (11-12-2012)
  • HAL Id : hal-00763628 , version 1
Cengis Hasan, Eitan Altman, Jean-Marie Gorce, Majed Haddad. Non-Cooperative Association Of Mobiles To Access Points Revisited. WiOpt'12: Modeling and Optimization in Mobile, Ad Hoc, and Wireless Networks, May 2012, Paderborn, Germany. pp.185-191. ⟨hal-00763628⟩
159 Consultations
76 Téléchargements
