Extended interface ID for virtual link selection in GeoNetworking to IPv6 Adaptation Sub-layer (GN6ASL)
We describe the limitation of Draft EN 302 636-6-1 V0.1.2 (2012-11). Note that this study is based on year December 2012 versions of the ETSI Standards and that the standards constantly evolve. As a result, parameters, primitives and virtual links on GN6ASL may have changed at the time of reading. We propose a solution to allocate different IPv6 address on each virtual interface in order to distinguish them without changing the addressing scheme in MAC address and GeoNetworking address. The proposition complies also with Dynamic Geographical Virtual Link (DVL).
