Lifetime estimation of moving vesicles in frequency-domain fluorescence lifetime imaging microscopy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a framework for correcting the effect of vesicles motion in frequency domain FLIM imaging. Estimation of movement and lifetime are decoupled and alternatively performed. Robust M-estimation is involved to improve the accuracy of our estimate. Our method has been evaluated with both simulated and real samples.
PRoudot_ISBI2012.pdf (142.82 Ko) Télécharger le fichier
hal-00763790 , version 1 (11-12-2012)
Philippe Roudot, Charles Kervrann, François Waharte. Lifetime estimation of moving vesicles in frequency-domain fluorescence lifetime imaging microscopy. IEEE International Symposium on Biomedical Imaging: From Nano to Macro, ISBI 2012, May 2012, Barcelona, Spain. pp.668-671, ⟨10.1109/ISBI.2012.6235636⟩. ⟨hal-00763790⟩
204 Consultations
183 Téléchargements
