Constraint augmentation in pseudo-singularly perturbed linear programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Programming, Series A Année : 2012
In this paper we study a linear programming problem with a linear perturbation introduced through a parameter $\epsilon > 0$. We identify and analyze an unusual asymptotic phenomenon in such a linear program. Namely, discontinuous limiting behavior of the optimal objective function value of such a linear program may occur even when the rank of the coefficient matrix of the constraints is unchanged by the perturbation. We show that, under mild conditions, this phenomenon is a result of the classical Slater constraint qualification being violated at the limit and propose an iterative, constraint augmentation approach for resolving this problem.
hal-00764284 , version 1 (12-12-2012)
Konstantin Avrachenkov, Regina Burachik, Jerzy Filar, Vladimir Gaitsgory. Constraint augmentation in pseudo-singularly perturbed linear programs. Mathematical Programming, Series A, 2012, 132 (1-2), pp.179-208. ⟨10.1007/s10107-010-0388-0⟩. ⟨hal-00764284⟩
Collections
INRIA INRIA2
70 Consultations
0 Téléchargements
