Foundational Issues in Touch-Screen Stroke Gesture Design - An Integrative Review - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Foundations and Trends in Human-Computer Interaction Année : 2012
The potential for using stroke gestures to enter, retrieve and select commands and text has been recently unleashed by the popularity of touchscreen devices. This monograph provides a state-of-the-art inte- grative review of a body of human-computer interaction research on stroke gestures. It begins with an analysis of the design dimensions of stroke gestures as an interaction medium. The analysis classifies gestures into analogue versus abstract gestures, gestures for com- mands versus for symbols, gestures with different orders of complexity, visual-spatial dependent and independent gestures, and finger versus stylus drawn gestures. Gesture interfaces such as the iOS interface, the Graffiti text entry method for Palm devices, marking menus, and the SHARK/ShapeWriter word-gesture keyboard, make different choices in this multi-dimensional design space. The main body of this work consists of reviewing and synthe- sizing some of the foundational studies in the literature on stroke gesture interaction, particularly those done by the authors in the last decade. The human performance factors covered include motor control complexity, visual and auditory feedback, and human memory capabil- ities in dealing with gestures. Based on these foundational studies this review presents a set of design principles for creating stroke gesture interfaces. These include making gestures analogous to physical effects or cultural conventions, keeping gestures simple and distinct, defining stroke gestures systematically, making them self-revealing, supporting appropriate levels of chunking, and facilitating progress from visually guided performance to recall-driven performance. The overall theme is on making learning gestures easier while designing for long-term efficiency. Important system implementation issues of stroke gesture interfaces such as gesture recognition algorithms and gesture design toolkits are also covered in this review. The monograph ends with a few call-to-action research topics.
fnt-gestures-survey-final.pdf (1.41 Mo) Télécharger le fichier
hal-00765046 , version 1 (18-12-2012)
Shumin Zhai, Per Ola Kristensson, Caroline Appert, Tue Haste Andersen, Xiang Cao. Foundational Issues in Touch-Screen Stroke Gesture Design - An Integrative Review. Foundations and Trends in Human-Computer Interaction, 2012, 5 (2), pp.97-205. ⟨10.1561/1100000012⟩. ⟨hal-00765046⟩
943 Consultations
2356 Téléchargements
