Experiments comparing precision of stereo-vision approaches for control of an industrial manipulator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Despite years of research in the area of robotics, the vast majority of industrial robots are still used in "teach-repeat" mode. This requires that the workpiece be in exactly the same position and orientation every time. In many high-volume robotics applications, this is not a problem, since the parts are likely to be fixtured anyway. However, in small to medium lot applications, this can be a significant limitation. In a previous work, we proposed an approach for vision based manipulation, which do not have these limitaitons. This paper proses a deep analysis of the accuracy of the method, its limitations, and a comprison with other approaches.
ISER_2012_paper1.7.pdf (306.88 Ko) Télécharger le fichier
hal-00765352 , version 1 (17-12-2012)
  • HAL Id : hal-00765352 , version 1
John-David Yoder, Jeffrey West, Eric Baumgartner, Mathias Perrollaz, Michael Seelinger, et al.. Experiments comparing precision of stereo-vision approaches for control of an industrial manipulator. Internaltional Symposium on Experimental Robotics, Jun 2012, Quebec, Canada. ⟨hal-00765352⟩
346 Consultations
470 Téléchargements
