Anti-Unification with Type Classes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The anti-unification problem is that of finding the most specific pattern of two terms. While dual to the unification problem, anti-unification has rarely been considered at the level of types. In this paper, we present an algorithm to compute the least general type of two types in Haskell, using the logic programming power of type classes. That is, we define a type class for which the type class instances resolution performs anti-unification. We then use this type class to define a type-safe embedding of aspects in Haskell.
main.pdf (272.44 Ko) Télécharger le fichier
hal-00765862 , version 1 (17-12-2012)
  • HAL Id : hal-00765862 , version 1
Nicolas Tabareau, Éric Tanter, Ismael Figueroa. Anti-Unification with Type Classes. Journées Francophones des Langages Applicatifs (JFLA), Feb 2013, Aussois, France. ⟨hal-00765862⟩
308 Consultations
239 Téléchargements
