Towards optimal priority assignments for real-time tasks with probabilistic arrivals and execution times - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
Dorin Maxim
  • Fonction : Auteur
  • PersonId : 884508
In this paper we present the problem of optimal priority assignments in fixed priority preemptive single processor systems where tasks have probabilistic arrivals and execution times.We show that Rate Monotic is not optimal for our problem.
rtsops2012CR.pdf (154.93 Ko) Télécharger le fichier
hal-00766057 , version 1 (17-12-2012)
  • HAL Id : hal-00766057 , version 1
Dorin Maxim. Towards optimal priority assignments for real-time tasks with probabilistic arrivals and execution times. 2012. ⟨hal-00766057⟩
71 Consultations
36 Téléchargements
