A simple Tsumego Generator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Generating problems is an interesting challenge, for both pedagogical purpose and for assessment. We propose a simple solution for generating problems, which can be used on a wide range of games and simulators, and evaluate it in the framework of the game of Go, providing problems from lowest amateur range to problems which are not trivial even for professional players.
tsumego_afterreviewing.pdf (140.93 Ko) Télécharger le fichier
hal-00766190 , version 1 (18-12-2012)
  • HAL Id : hal-00766190 , version 1
Ping-Chiang Chou, Shi-Jim Yen, Cheng-Wei Chou, Ching-Nung Lin, Chang-Shing Lee, et al.. A simple Tsumego Generator. GPW, 2012, Kanagawa, Japan. ⟨hal-00766190⟩
776 Consultations
577 Téléchargements
