Numerical simulation of piecewise-linear models of gene regulatory networks using complementarity systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2012
Gene regulatory networks control the response of living cells to changes in their environment. A class of piecewise-linear (PWL) models, which capture the switch-like interactions between genes by means of step functions, has been found useful for describing the dynamics of gene regulatory networks. The step functions lead to discontinuities in the right-hand side of the differential equations. This has motivated extensions of the PWL models based on differential inclusions and Filippov solutions, whose analysis requires sophisticated numerical tools. We present a method for the numerical analysis of one proposed extension, called Aizermann-Pyatnitskii (AP)-extension, by reformulating the PWL models as a mixed complementarity system (MCS). This allows the application of powerful methods developed for this class of nonsmooth dynamical systems, in particular those implemented in the Siconos platform. We also show that under a set of reasonable biological assumptions, putting constraints on the right-hand side of the PWL models, AP-extensions and classical Filippov (F-) extensions are equivalent. This means that the proposed numerical method is valid for a range of different solution concepts. We illustrate the practical interest of our approach through the numerical analysis of three well-known networks developed in the field of synthetic biology.
vincent4p.pdf (969.73 Ko) Télécharger le fichier
hal-00766266 , version 1 (31-01-2013)
  • HAL Id : hal-00766266 , version 1
Vincent Acary, Hidde de Jong, Bernard Brogliato. Numerical simulation of piecewise-linear models of gene regulatory networks using complementarity systems. Optimization: Computation, Theory and Modeling. Workshop III - Complementarity And Its Extensions, Dec 2012, Singapore, Singapore. 2012. ⟨hal-00766266⟩
418 Consultations
102 Téléchargements
