Next-Generation Model-based Variability Management: Languages and Tools - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Variability modelling and management is a key activity in a growing number of software engineering contexts, from software product lines to dynamic adaptive systems. Feature models are the defacto standard to formally represent and reason about commonality and variability of a software system. This tutorial aims at presenting next generation of feature modelling languages and tools, directly applicable to a wide range of model-based variability problems and application domains. Participants (being practitioners or academics, beginners or advanced) will learn the principles and foundations of languages and tool-supported techniques dedicated to the model-based management of variability.
NextGenVariabilityMODELS12-tutorial.pdf (102.23 Ko) Télécharger le fichier
hal-00767170 , version 1 (19-12-2012)
  • HAL Id : hal-00767170 , version 1
Mathieu Acher, Patrick Heymans, Philippe Collet, Philippe Lahire. Next-Generation Model-based Variability Management: Languages and Tools. MODELS 2012 - 15th International Conference on Model Driven Engineering Languages & Systems, Sep 2012, Innsbruck, Austria. ⟨hal-00767170⟩
870 Consultations
268 Téléchargements
