Keys and Pseudo-Keys Detection for Web Datasets Cleansing and Interlinking
This paper introduces a method for analyzing web datasets based on key dependencies. The classical notion of a key in relational databases is adapted to RDF datasets. In order to better deal with web data of variable quality, the definition of a pseudo-key is presented. An RDF vocabulary for representing keys is also provided. An algorithm to discover keys and pseudo-keys is described. Experimental results show that even for a big dataset such as DBpedia, the runtime of the algorithm is still reasonable. Two applications are further discussed: (i) detection of errors in RDF datasets, and (ii) datasets interlinking.
Autre [cs.OH]
