Anonymizing set-valued data by nonreciprocal recoding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Today there is a strong interest in publishing set-valued data in a privacy-preserving manner. Such data associate individuals to sets of values (e.g., preferences, shopping items, symptoms, query logs). In addition, an individual can be associated with a sensitive label (e.g., marital status, religious or political conviction). Anonymizing such data implies ensuring that an adversary should not be able to (1) identify an individual's record, and (2) infer a sensitive label, if such exists. Existing research on this problem either perturbs the data, publishes them in disjoint groups disassociated from their sensitive labels, or generalizes their values by assuming the availability of a generalization hierarchy. In this paper, we propose a novel alternative. Our publication method also puts data in a generalized form, but does not require that published records form disjoint groups and does not assume a hierarchy either; instead, it employs generalized bitmaps and recasts data values in a nonreciprocal manner; formally, the bipartite graph from original to anonymized records does not have to be composed of disjoint complete subgraphs. We configure our schemes to provide popular privacy guarantees while resisting attacks proposed in recent research, and demonstrate experimentally that we gain a clear utility advantage over the previous state of the art.
p1050-xue.pdf (542.93 Ko) Télécharger le fichier
hal-00768428 , version 1 (21-12-2012)
  • HAL Id : hal-00768428 , version 1
Mingqiang Xue, Panagiotis Karras, Chedy Raïssi, Jaideep Vaidya, Kian-Lee Tan. Anonymizing set-valued data by nonreciprocal recoding. KDD - The 18th ACM SIGKDD International Conference on Knowledge Discovery and Data Mining - 2012, Aug 2012, Beijing, China. ⟨hal-00768428⟩
291 Consultations
256 Téléchargements
