Geometrically-constrained Robust Time Delay Estimation Using Non-coplanar Microphone Arrays - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we present a geometrically-constrained time delay estimation method for sound source localization (gTDE). An algebraic analysis reveals that the method can deal with an arbitrary number of non-coplanar microphones. We derive a constrained non-linear optimization problem that can be solved using local convex programming. Unlike existing techniques, which consider pairwise TDE's, the proposed method optimally estimates a set of time delays that are consistent with the source's location. Extensive simulated experiments validate the method in the presence of noise and of reverberations.
alameda-eurasip2012.pdf (592.94 Ko) Télécharger le fichier
hal-00768763 , version 1 (23-12-2012)
  • HAL Id : hal-00768763 , version 1
Xavier Alameda-Pineda, Radu Horaud. Geometrically-constrained Robust Time Delay Estimation Using Non-coplanar Microphone Arrays. EUSIPCO 2012 - 20th European Signal Processing Conference, Aug 2012, Bucharest, Romania. pp.1309-1313. ⟨hal-00768763⟩
157 Consultations
228 Téléchargements
