A Voronoi-Based Hybrid Meshing Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2012
Jeanne Pellerin
Bruno Lévy
We introduce a method to build volumetric hybrid meshes suitable for finite element computations. The generated mesh is conformal to a set of input surfaces; thin sections are meshed with prisms, pyramids, and tetrahedra, while the remaining of the domain is meshed with Delaunay tetrahedra.
research_note_pellerin_imr_2012.pdf (2.44 Mo) Télécharger le fichier
hal-00770939 , version 1 (07-01-2013)
  • HAL Id : hal-00770939 , version 1
Jeanne Pellerin, Bruno Lévy, Guillaume Caumon. A Voronoi-Based Hybrid Meshing Method. 2012. ⟨hal-00770939⟩
192 Consultations
191 Téléchargements
