Heterogeneous Resource Allocation under Degree Constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Parallel and Distributed Systems Année : 2012
In this paper, we consider the problem of assigning a set of clients with demands to a set of servers with capacities and degree constraints. The goal is to find an allocation such that the number of clients assigned to a server is smaller than the server's degree and their overall demand is smaller than the server's capacity, while maximizing the overall throughput. This problem has several natural applications in the context of independent tasks scheduling or virtual machines allocation. We consider both the \emph{offline} (when clients are known beforehand) and the \emph{online} (when clients can join and leave the system at any time) versions of the problem. We first show that the degree constraint on the maximal number of clients that a server can handle is realistic in many contexts. Then, our main contribution is to prove that even if it makes the allocation problem more difficult (NP-Complete), a very small additive resource augmentation on the servers degree is enough to find in polynomial time a solution that achieves at least the optimal throughput. After a set of theoretical results on the complexity of the offline and online versions of the problem, we propose several other greedy heuristics to solve the online problem and we compare the \emph{performance} (in terms of throughput) and the \emph{cost} (in terms of disconnections and reconnections) of all proposed algorithms through a set of extensive simulation results.
MTBD-Final.pdf (257.22 Ko) Télécharger le fichier
MTBD-Appendix.pdf (162.28 Ko) Télécharger le fichier
Format : Autre
hal-00771773 , version 1 (09-01-2013)
Olivier Beaumont, Lionel Eyraud-Dubois, Hejer Rejeb, Christopher Thraves-Caro. Heterogeneous Resource Allocation under Degree Constraints. IEEE Transactions on Parallel and Distributed Systems, 2012, ⟨10.1109/TPDS.2012.175⟩. ⟨hal-00771773⟩
154 Consultations
217 Téléchargements
