Planning-based Approach for Optimizing the Display of Online Advertising Campaigns - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In a realistic context, the online advertisements have constraints such as a certain number of clicks to draw, as well as a lifetime. Furthermore, receiving a click is usually a very rare event. Thus, the problem of choosing which advertisement to display on a web page is inherently dynamic, and intimately combines combinato- rial and statistical issues. We introduce a planning based algorithm for optimizing the display of advertisements and investigate its performance through simulations on a realistic model designed with an important commercial web actor.
mload-2010.pdf (120.51 Ko) Télécharger le fichier
hal-00772512 , version 1 (10-01-2013)
  • HAL Id : hal-00772512 , version 1
Sertan Girgin, Jérémie Mary, Philippe Preux, Olivier Nicol. Planning-based Approach for Optimizing the Display of Online Advertising Campaigns. NIPS workshop on Machine Learning in Online ADvertising, Dec 2010, Whistler, Canada. ⟨hal-00772512⟩
183 Consultations
183 Téléchargements
