Methods for Designing Tangible UI: A First Comparative Case Study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Katarzyna Borgiel
  • Fonction : Auteur
  • PersonId : 935181
Nadine Couture
Jens Geelhaar
  • Fonction : Auteur
  • PersonId : 1040267
Nawel Takouachet
  • Fonction : Auteur
  • PersonId : 915122
Sébastien Kubicki
Yvonne Jansen
Amira Bouadid
  • Fonction : Auteur
  • PersonId : 935182
In this work-in-progress, we present early comparative experiences with methods for designing tangible user interfaces (TUIs). Groups of designers used different approaches for design in the context of a concrete case study: a TUI for controlling LED lighting within hotel rooms. From the results of the groups and methods, we wish to discuss the first comparison between different approaches. Eventually, our aim is to provide a consensual comparison of benefits and drawbacks of each approach, as such a consensual result could be highly beneficial to designers.
gt_design_tei13.pdf (213.54 Ko) Télécharger le fichier
hal-00772570 , version 1 (10-12-2018)
  • HAL Id : hal-00772570 , version 1
Céline Coutrix, Guillaume Rivière, Katarzyna Borgiel, Julien Castet, Nadine Couture, et al.. Methods for Designing Tangible UI: A First Comparative Case Study. TEI 2013 Work in progress, 7th International Conference on Tangible, Embedded and Embodied Interaction, Feb 2013, Barcelona, Spain. ⟨hal-00772570⟩
677 Consultations
371 Téléchargements
