Transfer in Reinforcement Learning: a Framework and a Survey - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2012
Alessandro Lazaric
Transfer in reinforcement learning is a novel research area that focuses on the development of methods to transfer knowledge from a set of source tasks to a target task. Whenever the tasks are \textit{similar}, the transferred knowledge can be used by a learning algorithm to solve the target task and significantly improve its performance (e.g., by reducing the number of samples needed to achieve a nearly optimal performance). In this chapter we provide a formalization of the general transfer problem, we identify the main settings which have been investigated so far, and we review the most important approaches to transfer in reinforcement learning.
transfer.pdf (428.94 Ko) Télécharger le fichier
hal-00772626 , version 1 (10-01-2013)
Alessandro Lazaric. Transfer in Reinforcement Learning: a Framework and a Survey. Marco Wiering, Martijn van Otterlo. Reinforcement Learning - State of the art, 12, Springer, pp.143-173, 2012, ⟨10.1007/978-3-642-27645-3_5⟩. ⟨hal-00772626⟩
340 Consultations
5021 Téléchargements
