Discrete-time normal form for left invertibility problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue European Journal of Control Année : 2009
This paper deals with the design of quadratic and higher order normal forms for the left invertibility problem. The linearly observable case and one-dimensional linearly unobservable case are investigated. The interest of such a study in the design of a delayed discrete-time observer is examined. The example of the Burgers map with unknown input is treated and a delayed discrete-time observer is designed. Finally, some simulated results are commented.
articleJPM2b.pdf (201.31 Ko) Télécharger le fichier
hal-00772645 , version 1 (10-01-2013)
Mohamed Djemai, Jean-Pierre Barbot, Inam Belmouhoub. Discrete-time normal form for left invertibility problem. European Journal of Control, 2009, 15 (2), pp.194-204. ⟨10.3166/ejc.15.194-204⟩. ⟨hal-00772645⟩
319 Consultations
358 Téléchargements
