A Focused Approach to Combining Logics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annals of Pure and Applied Logic Année : 2011
We present a compact sequent calculus LKU for classical logic organized around the concept of polarization. Focused sequent calculi for classical, intuitionistic, and multiplicative-additive linear logics are derived as fragments of the host system by varying the sensitivity of specialized structural rules to polarity information. We identify a general set of criteria under which cut elimination holds in such fragments. From cut elimination we derive a unified proof of the completeness of focusing. Furthermore, each sublogic can interact with other fragments through cut. We examine certain circumstances, for example, in which a classical lemma can be used in an intuitionistic proof while preserving intuitionistic provability. We also examine the possibility of defining classical-linear hybrid logics.
lku.pdf (297.7 Ko) Télécharger le fichier
hal-00772736 , version 1 (11-01-2013)
Chuck Liang, Dale Miller. A Focused Approach to Combining Logics. Annals of Pure and Applied Logic, 2011, ⟨10.1016/j.apal.2011.01.012⟩. ⟨hal-00772736⟩
122 Consultations
185 Téléchargements
