On the inverse optimal control problems of the human locomotion: stability and robustness of the minimizers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Sciences Année : 2013
In recent papers models of the human locomotion by means of an optimal control problem have been proposed. In this paradigm, the trajectories are assumed to be solutions of an optimal control problem whose cost has to be determined. The purpose of the present paper is to analyze the class of optimal control problems defined in this way. We prove strong convergence result for their solutions on the one hand for perturbations of the initial and final points (stability), and on the other hand for perturbations of the cost (robustness).
chittaro_jean_mason.pdf (239.74 Ko) Télécharger le fichier
hal-00774720 , version 1 (15-01-2013)
Francesca Chittaro, Frédéric Jean, Paolo Mason. On the inverse optimal control problems of the human locomotion: stability and robustness of the minimizers. Journal of Mathematical Sciences, 2013, 195 (3), pp.269-287. ⟨10.1007/s10958-013-1579-z⟩. ⟨hal-00774720⟩
769 Consultations
333 Téléchargements
