Algebraic Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2012
Algebraic algorithms deal with numbers, vectors, matrices, polynomials, formal power series, exponential and differential polynomials, rational functions, algebraic sets, curves and surfaces. In this vast area, manipulation with matrices and polynomials is fundamental for modern computations in Sciences, Engineering, and Signal and Image Processing.
16et-9Jul.pdf (357.13 Ko) Télécharger le fichier
hal-00776270 , version 1 (15-01-2013)
  • HAL Id : hal-00776270 , version 1
Ioannis Z. Emiris, Victor Y. Y. Pan, Elias Tsigaridas. Algebraic Algorithms. Teofilo Gonzalez. Computing Handbook Set - Computer Science, I, CRC Press, 2012. ⟨hal-00776270⟩
300 Consultations
3351 Téléchargements
