Improving multifrontal methods by means of block low-rank representations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2013
Matrices coming from elliptic Partial Differential Equations (PDEs) have been shown to have a low-rank property: well defined off-diagonal blocks of their Schur complements can be approximated by low-rank products. Given a suitable ordering of the matrix which gives to the blocks a geometrical meaning, such approximations can be computed using an SVD or a rank-revealing QR factorization. The resulting representation offers a substantial reduction of the memory requirement and gives efficient ways to perform many of the basic dense algebra operations. Several strategies have been proposed to exploit this property. We propose a low-rank format called Block Low-Rank (BLR), and explain how it can be used to reduce the memory footprint and the complexity of direct solvers for sparse matrices based on the multifrontal method. We present experimental results that show how the BLR format delivers gains that are comparable to those obtained with hierarchical formats such as Hierarchical matrices (H matrices) and Hierarchically Semi-Separable (HSS matrices) but provides much greater flexibility and ease of use which are essential in the context of a general purpose, algebraic solver.
RR-8199.pdf (1.25 Mo) Télécharger le fichier
hal-00776859 , version 1 (31-01-2013)
  • HAL Id : hal-00776859 , version 1
Patrick Amestoy, Cleve Ashcraft, Olivier Boiteau, Alfredo Buttari, Jean-Yves L'Excellent, et al.. Improving multifrontal methods by means of block low-rank representations. [Research Report] INRIA RR-8199, INRIA. 2013. ⟨hal-00776859⟩
432 Consultations
827 Téléchargements
