Size Does Matter: Two Certified Abstractions to Disprove Entailment in Intuitionistic and Classical Separation Logic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
We describe an algorithm to disprove entailment between separation logic formulas. We abstract models of formulas by their size and check whether two formulas have models whose sizes are compatible. Given two formulas A and B that do not have compatible models, we can conclude that A 0 B. We provide two different abstractions (of different precision) of models. Our algorithm is of interest wherever entailment checking is performed (such as in program verifiers).
size.pdf (134.27 Ko) Télécharger le fichier
hal-00777577 , version 1 (18-01-2013)
  • HAL Id : hal-00777577 , version 1
Clément Hurlin, François Bobot, Alexander Summers. Size Does Matter: Two Certified Abstractions to Disprove Entailment in Intuitionistic and Classical Separation Logic. International Workshop on Aliasing, Confinement and Ownership in object-oriented programming (IWACO'09), Jul 2009, Genova, Italy. ⟨hal-00777577⟩
182 Consultations
164 Téléchargements
