Algebraic Stability Criteria and Symbolic Derivation of Stability Conditions for Feedback Control Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Control Année : 2012
Dongming Wang
  • Fonction : Auteur
  • PersonId : 835371
This article provides algebraic settings of the stability criteria of Nyquist and Popov and the circle criterion for closed-loop linear control systems with linear or nonlinear feedback whose transfer functions are rational ones with integer coefficients. The proposed settings make use of algebraic methods of parametric curve implicitisation, real root isolation, symbolic integration and quantifier elimination and allow one to derive exact stability conditions for feedback control systems with symbolic computation. An example is presented to illustrate the algebraic approach and its effectiveness. Some numerical stability results obtained previously are confirmed.
Fichier non déposé
hal-00779248 , version 1 (21-01-2013)
Dongming Wang. Algebraic Stability Criteria and Symbolic Derivation of Stability Conditions for Feedback Control Systems. International Journal of Control, 2012, 85 (10), pp.1414-1421. ⟨10.1080/00207179.2012.686633⟩. ⟨hal-00779248⟩
127 Consultations
0 Téléchargements
