Improving Angular Speed Uniformity by Optimal C⁰ Piecewise Reparameterization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Dongming Wang
  • Fonction : Auteur
  • PersonId : 835371
Hoon Hong
  • Fonction : Auteur
  • PersonId : 935617
We adapt the C° piecewise Möbius transformation to compute a C° piecewise-rational reparameterization of any plane curve that approximates to the arc-angle parameterization of the curve. The method proposed on the basis of this transformation can achieve highly accurate approximation to the arc-angle parameterization. A mechanism is developed to optimize the transformation using locally optimal partitioning of the unit interval. Experimental results are provided to show the effectiveness and efficiency of the reparameterization method.
Fichier non déposé
hal-00779259 , version 1 (21-01-2013)
Jing Yang, Dongming Wang, Hoon Hong. Improving Angular Speed Uniformity by Optimal C⁰ Piecewise Reparameterization. CASC 2012 - 14th International Workshop on Computer Algebra in Scientific Computing, Sep 2012, Maribor, Slovenia. pp.349-360, ⟨10.1007/978-3-642-32973-9_29⟩. ⟨hal-00779259⟩
135 Consultations
0 Téléchargements
