Gestures vs. Postures: 'Gestural' Touch Interaction in 3D Environments
We revisit the concept of a 'gesture' and discuss it, in particular, in the context of 3D interaction. We argue that one should distinguish between postures, quasi-postures, and gestures and that the first two should be (and are currently) preferred in 3D interfaces for directly-manipulative interaction with the environment in user-maintained modes. In scientific visualization we saw use cases of quasi-postures, suggesting that they are one way to re-use the same input space in order to facilitate several means of exploration.
Isenberg_2012_GPG.pdf (428.83 Ko)
Télécharger le fichier
Format : Figure, Image
