Visual Abstraction and Stylisation of Maps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The Cartographic Journal Année : 2013
Tobias Isenberg
We explore visual map abstraction for the generation of stylized renderings of 2D map data. We employ techniques that are centered around the concept of shape simplification and graph layout and that allow iterative abstraction of 2D maps. We use data from publicly available sources and show how we can iteratively generate aesthetic renditions of these maps. These renditions do not have the goal to allow for navigation tasks but instead show the map data in a distorted manner. The techniques used to create these images apply simplification, abstraction/generalization, and displacement operations to the map elements in varying orders and add stylistic shading to produce aesthetic renditions for print or electronic displays. The degree of abstraction/generalization can be individually chosen and determines the characteristics of the distorted map: whether components retain their shape, degenerate, or are processed in a manner that the abstraction becomes the focus of the image rather than the underlying map data. The renditions can be further personalized by choosing shading and colors for this shading. Together, the presented techniques allow for playful and creative exploration of aesthetic renditions of 2D map data.
Isenberg_2013_VAS.pdf (2.74 Mo) Télécharger le fichier
Format : Figure, Image
hal-00781500 , version 1 (13-05-2013)
Tobias Isenberg. Visual Abstraction and Stylisation of Maps. The Cartographic Journal, 2013, 50 (1), pp.8--18. ⟨10.1179/1743277412Y.0000000007⟩. ⟨hal-00781500⟩
165 Consultations
627 Téléchargements
