Spatially Continuous Change of Abstraction in Molecular Visualization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Based on an approach for the temporal change of abstraction in molecular visualization we describe how to achieve a spatially explicit control of abstraction. This allows us to depict different abstraction stages of a single molecule in a single still-image visualization. This approach works best for long, linear molecules with repeating substructures that allow viewers to visually compare the continuous representational changes of these parts.
Lueks_2011_SCC.pdf (1.63 Mo) Télécharger le fichier
Format : Figure, Image
hal-00781520 , version 1 (27-01-2013)
  • HAL Id : hal-00781520 , version 1
Wouter Lueks, Ivan Viola, Matthew van Der Zwan, Henk Bekker, Tobias Isenberg. Spatially Continuous Change of Abstraction in Molecular Visualization. Abstracts of 1st IEEE Symposium on Biological Data Visualization (BioVis 2011, October 23--24, 2011, Providence, RI, USA), Oct 2011, Los Alamitos, United States. ⟨hal-00781520⟩
395 Consultations
280 Téléchargements
