Least committed basic belief density induced by a multivariate Gaussian: Formulation with applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Approximate Reasoning Année : 2008
We consider here the case where our knowledge is partial and based on a betting density function which is n-dimensional Gaussian. The explicit formulation of the least committed basic belief density (bbd) of the multivariate Gaussian pdf is provided in the transferable belief model (TBM) framework. Beliefs are then assigned to hyperspheres and the bbd follows a khi-2 distribution. Two applications are also presented. The first one deals with model based classification in the joint speed-accel- eration feature space. The second is devoted to joint target tracking and classification: the tracking part is performed using a Rao-Blackwellized particle filter, while the classification is carried out within the developed TBM scheme.
hal-00782301 , version 1 (29-01-2013)
Francois Caron, Branko Ristic, Emmanuel Duflos, Philippe Vanheeghe. Least committed basic belief density induced by a multivariate Gaussian: Formulation with applications. International Journal of Approximate Reasoning, 2008, 48 (2), pp.419-436. ⟨10.1016/j.ijar.2006.10.003⟩. ⟨hal-00782301⟩
208 Consultations
0 Téléchargements
