Optimal policies search for sensor management : Application to the ESA radar - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This paper introduces a new approach to solve sensor management problems. Classically sensor management problems can be well formalized as partially-observed Markov decision processes (POMPD). The original approach developped here consists in deriving the optimal parameterized policy based on a stochastic gradient estimation. We assume in this work that it is possible to learn the optimal policy off-line (in simulation) using models of the environement and of the sensor(s). The learned policy can then be used to manage the sensor(s). In order to approximate the gradient in a stochastic context, we introduce a new method to approximate the gradient, based on infinitesimal perturbation approximation (IPA). The effectiveness of this general framework is illustrated by the managing of an electronically scanned array radar. First simulations results are finally proposed.
Fichier non déposé
hal-00782346 , version 1 (29-01-2013)
  • HAL Id : hal-00782346 , version 1
Thomas Bréhard, Pierre-Arnaud Coquelin, Emmanuel Duflos, Philippe Vanheeghe. Optimal policies search for sensor management : Application to the ESA radar. 11th International Conference on Information Fusion, 2008., Jun 2008, Cologne, Germany. pp.1 - 8. ⟨hal-00782346⟩
86 Consultations
0 Téléchargements
