Artificial evolution for PET and SPECT reconstruction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Franck P Vidal
Connectez-vous pour contacter l'auteur
Evelyne Lutton
Jean Louchet
  • Fonction : Auteur
  • PersonId : 914138
Jean-Marie Rocchisani
  • Fonction : Auteur
  • PersonId : 936310
We propose an evolutionary approach for image reconstruction in nuclear medicine. Our method is based on a cooperative coevolution strategy (also called Parisian evolution): the "fly algorithm". Method and Materials: Each individual, or fly, corresponds to a 3D point that mimics a radioactive emitter, i.e. a stochastic simulation of annihilation events is performed to compute the fly's illumination pattern. For each annihilation, a photon is emitted in a random direction, and a second photon is emitted in the opposite direction. The line between two detected photons is called line of response (LOR). If both photons are detected by the scanner, the fly's illumination pattern is updated. The LORs of every fly are aggregated to form the population total illumination pattern. Using genetic operations to optimize the position of positrons, the population of flies evolves so that the population total pattern matches measured data. The final population of flies approximates the radioactivity concentration. Results: We have developed numerical phantom models to assess the reconstruction algorithm. To date, no scattering and no tissue attenuation have been considered. Whilst this is not physically correct, it allows us to test and validate our approach in the simplest cases. Preliminary results show the validity of this approach in both 2D and fully-3D modes. In particular, the size of objects, and their relative concentrations can be retrieved in the 2D mode. In fully-3D, complex shapes can be reconstructed. Conclusions: An evolutionary approach for PET reconstruction has been proposed and validated using simple test cases. Further work will therefore include the use of more realistic input data (including random events and scattering), which will finally lead to implement the correction of scattering within our algorithm. A comparison study against ML-EM and/or OS-EM methods will also need to be conducted.
PosterVidalAAPM-2010.pdf (469.94 Ko) Télécharger le fichier
hal-00783332 , version 1 (01-02-2013)
  • HAL Id : hal-00783332 , version 1
Franck P Vidal, Evelyne Lutton, Jean Louchet, Jean-Marie Rocchisani. Artificial evolution for PET and SPECT reconstruction. AAPM Annual Meeting, 2010, Philadelphia, United States. ⟨hal-00783332⟩
347 Consultations
277 Téléchargements
