Universal and efficient compressed sensing by spread spectrum and application to realistic Fourier imaging techniques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue EURASIP Journal on Advances in Signal Processing Année : 2012
Pierre Vandergheynst
  • Fonction : Auteur
  • PersonId : 839985
Yves Wiaux
  • Fonction : Auteur
  • PersonId : 858885
We advocate a compressed sensing strategy that consists of multiplying the signal of interest by a wide bandwidth modulation before projection onto randomly selected vectors of an orthonormal basis. First, in a digital setting with random modulation, considering a whole class of sensing bases including the Fourier basis, we prove that the technique is universal in the sense that the required number of measurements for accurate recovery is optimal and independent of the sparsity basis. This universality stems from a drastic decrease of coherence between the sparsity and the sensing bases, which for a Fourier sensing basis relates to a spread of the original signal spectrum by the modulation (hence the name "spread spectrum"). The approach is also efficient as sensing matrices with fast matrix multiplication algorithms can be used, in particular in the case of Fourier measurements. Second, these results are confirmed by a numerical analysis of the phase transition of the ℓ1-minimization problem. Finally, we show that the spread spectrum technique remains effective in an analog setting with chirp modulation for application to realistic Fourier imaging. We illustrate these findings in the context of radio interferometry and magnetic resonance imaging.
1687-6180-2012-6.pdf (446.53 Ko) Télécharger le fichier
1687-6180-2012-6.xml (168.72 Ko) Télécharger le fichier
Format : Autre
hal-00784410 , version 1 (04-02-2013)
Gilles Puy, Pierre Vandergheynst, Rémi Gribonval, Yves Wiaux. Universal and efficient compressed sensing by spread spectrum and application to realistic Fourier imaging techniques. EURASIP Journal on Advances in Signal Processing, 2012, 2012 (1), pp.6. ⟨10.1186/1687-6180-2012-6⟩. ⟨hal-00784410⟩
520 Consultations
349 Téléchargements
