Modeling lymphocyte homing and encounters in lymph nodes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue BMC Bioinformatics Année : 2009
Background
The efficiency of lymph nodes depends on tissue structure and organization, which allow the coordination of lymphocyte traffic. Despite their essential role, our understanding of lymph node specific mechanisms is still incomplete and currently a topic of intense research.
Results
In this paper, we present a hybrid discrete/continuous model of the lymph node, accounting for differences in cell velocity and chemotactic response, influenced by the spatial compartmentalization of the lymph node and the regulation of cells migration, encounter, and antigen presentation during the inflammation process.
Conclusion
Our model reproduces the correct timing of an immune response, including the observed time delay between duplication of T helper cells and duplication of B cells in response to antigen exposure. Furthermore, we investigate the consequences of the absence of dendritic cells at different times during infection, and the dependence of system dynamics on the regulation of lymphocyte exit from lymph nodes. In both cases, the model predicts the emergence of an impaired immune response, i.e., the response is significantly reduced in magnitude. Dendritic cell removal is also shown to delay the response time with respect to normal conditions.
1471-2105-10-387.pdf (876.78 Ko) Télécharger le fichier
1471-2105-10-387.xml (104.82 Ko) Télécharger le fichier
Format : Autre
hal-00784447 , version 1 (04-02-2013)
Valentina Baldazzi, Paola Paci, Massimo Bernaschi, Filippo Castiglione. Modeling lymphocyte homing and encounters in lymph nodes. BMC Bioinformatics, 2009, 10 (1), pp.387. ⟨10.1186/1471-2105-10-387⟩. ⟨hal-00784447⟩
213 Consultations
271 Téléchargements
