Fast reproducible identification and large-scale databasing of individual functional cognitive networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue BMC Neuroscience Année : 2007
Background
Although cognitive processes such as reading and calculation are associated with reproducible cerebral networks, inter-individual variability is considerable. Understanding the origins of this variability will require the elaboration of large multimodal databases compiling behavioral, anatomical, genetic and functional neuroimaging data over hundreds of subjects. With this goal in mind, we designed a simple and fast acquisition procedure based on a 5-minute functional magnetic resonance imaging (fMRI) sequence that can be run as easily and as systematically as an anatomical scan, and is therefore used in every subject undergoing fMRI in our laboratory. This protocol captures the cerebral bases of auditory and visual perception, motor actions, reading, language comprehension and mental calculation at an individual level.
Results
81 subjects were successfully scanned. Before describing inter-individual variability, we demonstrated in the present study the reliability of individual functional data obtained with this short protocol. Considering the anatomical variability, we then needed to correctly describe individual functional networks in a voxel-free space. We applied then non-voxel based methods that automatically extract main features of individual patterns of activation: group analyses performed on these individual data not only converge to those reported with a more conventional voxel-based random effect analysis, but also keep information concerning variance in location and degrees of activation across subjects.
Conclusion
This collection of individual fMRI data will help to describe the cerebral inter-subject variability of the correlates of some language, calculation and sensorimotor tasks. In association with demographic, anatomical, behavioral and genetic data, this protocol will serve as the cornerstone to establish a hybrid database of hundreds of subjects suitable to study the range and causes of variation in the cerebral bases of numerous mental processes.
1471-2202-8-91.pdf (2.39 Mo) Télécharger le fichier
1471-2202-8-91-S1.TIFF (1.66 Mo) Télécharger le fichier
1471-2202-8-91-S2.DOC (31.5 Ko) Télécharger le fichier
1471-2202-8-91.xml (223.42 Ko) Télécharger le fichier
Format : Autre
Format : Autre
Format : Autre
hal-00784462 , version 1 (04-02-2013)
Philippe Pinel, Bertrand Thirion, Sébastien Meriaux, Antoinette Jobert, Julien Serres, et al.. Fast reproducible identification and large-scale databasing of individual functional cognitive networks. BMC Neuroscience, 2007, 8 (1), pp.91. ⟨10.1186/1471-2202-8-91⟩. ⟨hal-00784462⟩
399 Consultations
241 Téléchargements
