Design and Assessment of an Intelligent Activity Monitoring Platform - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue EURASIP Journal on Advances in Signal Processing Année : 2005
We are interested in designing a reusable and robust activity monitoring platform. We propose three good properties that an activity monitoring platform should have to enable its reusability for different applications and to insure performance quality: (1) modularity and flexibility of the architecture, (2) separation between the algorithms and the a priori knowledge they use, and (3) automatic evaluation of algorithm results. We then propose a development methodology to fulfill the last two properties. The methodology consists in the interaction between end-users and developers during the whole development of a specific monitoring system. To validate our approach, we present a platform used to generate activity monitoring systems dedicated to specific applications, we also describe in details the technical validation and the end-user assessment of an automatic metro monitoring system built with the platform and briefly the validation results for bank agency monitoring and building access control.
1687-6180-2005-318538.pdf (772.89 Ko) Télécharger le fichier
1687-6180-2005-318538.xml (3.77 Ko) Télécharger le fichier
Format : Autre
hal-00784483 , version 1 (04-02-2013)
  • HAL Id : hal-00784483 , version 1
Alberto Avanzi, François Brémond, Christophe Tornieri, Monique Thonnat. Design and Assessment of an Intelligent Activity Monitoring Platform. EURASIP Journal on Advances in Signal Processing, 2005, 2005 (14), pp.318538. ⟨hal-00784483⟩
Collections
INRIA INRIA2
71 Consultations
201 Téléchargements
