Case studies in discrete control for autonomic system administration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents examples of autonomic system administration issues that can be addressed and solved as discrete control problems. This shows evidence of the relevance of control techniques for the discrete aspects of closed-loop control of computing systems. The model-based control of adaptive and reconfigurable systems is considered via a reactive programming language, based on discrete controller synthesis (DCS) techniques. We identify control problems in autonomic systems belonging to the class of logical, discrete systems, and illustrate how to solve them using DCS.
febid2011.pdf (214.04 Ko) Télécharger le fichier
hal-00784971 , version 1 (05-02-2013)
  • HAL Id : hal-00784971 , version 1
Fabienne Boyer, Noël de Palma, Gwenaël Delaval, Olivier Gruber, Eric Rutten. Case studies in discrete control for autonomic system administration. Sixth International Workshop on Feedback Control Implementation and Design in Computing Systems and Networks (FeBID 2011), Jun 2011, Karlsruhe, Germany. ⟨hal-00784971⟩
219 Consultations
106 Téléchargements
